Connect HT-M01S to LoRa Server¶
Summary¶
This article aims to describe how to connect HT-M01S Gateway to a LoRa server, such as TTN/TTS, ChirpStack, which facilitates secondary development and rapid deployment of LoRa devices.
Before all operation, make sure the HT-M01S is runing well . If not, please refer to this HT-M01S Quick Start document.
Connect to TTN/TTS¶
Register a LoRa gateway in TTN¶
Select a cluster in the TTN console page to start adding devices and gateways. Or start adding devices and gateways in TTS console.
Create a new gateway.
Fill in the HT-M01S information as shown below and complete the addition.
Gateway EUI – The unique ID of HT-M01S gateway, view from the display screen of the HT-M01S or view through the serial port (the gateway ID will be printed through the serial port when the HT-M01S starts).
Gateway ID – Generated by default.
Gateway name – Filled in by the user, can be filled in arbitrarily.
Frequency Plan – Matches the LoRa band configuration in HT-M01S.
Configure the Gateway¶
In the HT-M01S gateway, the server address, port, frequency band, and channel need to be configured. The server address, port, frequency band and channel are configured in the “HT-M01S Config” interface, please refer to the HT-M01S Quick Start document.
Check the server address in the gateway details.
View gateway status, it is runing:
Connect to ChirpStack Server¶
ChirpStack Installation guide: https://www.chirpstack.io/overview/
ChirpStack support forum: https://forum.chirpstack.io/
ChirpStack Gateway Bridge¶
One thing need attention! the ChirpStack need a special service named Gateway Bridge
, which converts LoRa® Packet Forwarder protocols into a ChirpStack Network Server common data-format(JSON and Protobuf).
the Gateway Bridge
service can running on the Raspberry Pi or the ChirpStack server.
Register LoRa Gateway in ChirpStack¶
Gateway ID – The unique ID of HT-M01S gateway, view from the display screen of the HT-M01S or view through the serial port (the gateway ID will be printed through the serial port when the HT-M01S starts).
Connect to ChirpStack server¶
