Connect HT-M02 to a LoRa Server
This article aims to describe how to connect HT-M02 Gateway to a LoRa server, such as TTN, ChirpStack, which facilitates secondary development and rapid deployment of LoRa devices.
Before all operation, make sure the HT-M02 is runing well . If not, please refer to this HT-M02(4G/LTE) Quick Start document.
Get the Gateway EUI
Generally, the EUI of the gateway will be pasted on the surface of the gateway.
The Gateway EUI also can be read via this command:
cat lora/packet_forwarder/lora_pkt_fwd/local_conf.json
If need to change the Gateway EUI for some reason, you can directly modify the file, and the modified EUI will take effect after restarting.
Connect to TTN
Register a LoRa gateway in TTN
Create and active an account in TTN. Select Gateway in the console page.
Fill in the HT-M02 information as shown below and complete the addition.
  • Gateway EUI – The unique ID of HT-M02 gateway;
  • I’m using the legacy packet forwarder – Must select this;
  • Frequency Plan – Must matach the LoRa band configuration in HT-M02;
  • Router – Must use the default router allocated by TTN system.
That four points are the key to success connection with TTN.
Connect to TTN
In the HT-M02 gateway, only the server address and port need to be configured.
config the server address and port in global_conf.json:
sudo nano lora/packet_forwarder/lora_pkt_fwd/global_conf.json
At the end of this file, make suitable changes:
  "server_address": "router.cn.thethings.network", /*The server IP address or domain*/
  "serv_port_up": 1700,
  "serv_port_down": 1700,
ctrl + O to save and ctrl + X to exit, and restart the service:
sudo systemctl restart lrgateway
Check whether the system running normally:
sudo systemctl status lrgateway
The TTN’s router addresses for different region:
https://www.thethingsnetwork.org/docs/gateways/packet-forwarder/semtech-udp.html#router-addresses
View gateway status, it is runing::
Connect to ChirpStack server
ChirpStack Gateway Bridge
One thing need attention! the ChirpStack need a special service named Gateway Bridge, which converts LoRa® Packet Forwarder protocols into a ChirpStack Network Server common data-format(JSON and Protobuf).
the Gateway Bridge service can running on the Raspberry Pi or the ChirpStack server.
Register LoRa Gateway in ChirpStack
  • Gateway ID – The unique ID of the HT-M02 gateway.
  "server_address": "router.eu.thethings.network", /*The server IP address or domain*/
