Add More Region Support on PicoGW UI
PicoGW UI is provided by Semtech®, allow users running a Pico Cell LoRa Gateway (HT-M01) on Windows® with directly UI.
But PicoGW_UI only provided four region support by default.
Suppose you need to add support for AU915_SB2 (AU915 Sub-band 2 for TTN)
  • Clone or download this repository: https://github.com/HelTecAutomation/lorasdk;
  • Rename global_conf_AU915_SB2.json to global_conf.json;
  • Copy global_conf.json to C:\Users\user name\AppData\Roaming\Semtech\PicoGW_UI path and replace the current one;
  • Reopen PicoGW_UI and choose Keep the current gobal conf.
Now, the PicoGW_UI will work on the definition of global_conf.json.
External resources
