Connect HT-M00 to LoRa Server
This article aims to describe how to connect HT-M00 Gateway to a LoRa server, ssuch as TTN/TTS, ChirpStack, which facilitates secondary development and rapid deployment of LoRa devices.
Before all operation, make sure the HT-M00 is runing well . If not, please refer to this HT-M00 Quick Start document.
Connect to TTN/TTS
Register a LoRa gateway in TTN
Select a cluster in the TTN console page to start adding devices and gateways. Or start adding devices and gateways in TTS console.
Create a new gateway.
Fill in the HT-M00 information as shown below and complete the addition.
Gateway EUI – The unique ID of HT-M00 gateway, view from the display screen of the HT-M00 or view through the serial port (the gateway ID will be printed through the serial port when the HT-M00 starts).
Gateway ID – Generated by default.
Gateway name – Filled in by the user, can be filled in arbitrarily.
Frequency Plan – Matches the LoRa band configuration in HT-M00.
Configure the Gateway
In the HT-M00 gateway, the server address, port, frequency band, and channel need to be configured. The server address, port, frequency band and channel are configured in the “HT-M00 Config” interface, please refer to the HT-M00 Quick Start document.
Check the server address in the gateway details.
View gateway status, it is runing:
Connect to ChirpStack Server
ChirpStack Installation guide: https://www.chirpstack.io/overview/
ChirpStack support forum: https://forum.chirpstack.io/
ChirpStack Gateway Bridge
One thing need attention! the ChirpStack need a special service named Gateway Bridge, which converts LoRa® Packet Forwarder protocols into a ChirpStack Network Server common data-format(JSON and Protobuf).
the Gateway Bridge service can running on the Raspberry Pi or the ChirpStack server.
Register LoRa Gateway in ChirpStack
Gateway ID – The unique ID of HT-M00 gateway, view from the display screen of the HT-M00 or view through the serial port (the gateway ID will be printed through the serial port when the HT-M00 starts).
