Frequently Asked Questions
Can’t Download Firmware
Use a better USB cable, or change a USB socket;
Check and make sure the CP210x drive had been correctly installed, users can refer to this document: Establish Serial Connection;
Press “PRG” button before upload.
Node to node communication
On the premise of no hardware problem, LoRa nodes can communicate with each other node-to-node. The key to success node-to-node communication need make sure the following 7 points the same:
The same sending and listening frequency:
LoRa.setFrequency(frequency);
The same bandwidth:
LoRa.setSignalBandwidth(signalBandwidth);
The same coding rate:
LoRa.setCodingRate4(codingRateDenominator);
The same preamble length:
LoRa.setPreambleLength(preambleLength);
The same sync word:
LoRa.setSyncWord(syncWord);
The status of
LORA_IQ_INVERSION
is the same;the same
SPREADING FACTOR
Know more information about LoRa node-to-node communication, please refer to LoRa basic library APIs: https://github.com/HelTecAutomation/Heltec_ESP32/blob/master/src/lora/API.md
Meshtastick
The device uses the firmware of Wireless Stick Lite, it does not have a display function.
