HeltecTM ESP32+LoRa Series Frequently Asked Questions
Unable to upload program
Unable to find port
  • Use a better USB cable, or change a USB socket;
  • Press “PRG/BOOT/USER” button before plugin. Note that reinsertion may cause the serial number to change.
Port found, but unable to upload
  • Check if the serial port is occupied elsewhere.
Another Communication Bus Usage Example
System Reset All the Time
According to the situation we have collected so far, the most likely to cause a constant reset problem may have two reasons:
  • Power supply problem: please make sure the voltage of USB ≥ 4.7V, 300mA;
  • You chose an error board: because each type of board may have a different FLASH size, and they have a different partition map, it will cause the internal logic error.
About WiFi LoRa 32(V2) Sleep Current Test
Use the battery to power the development board, and connect an ammeter to the positive pole of the battery. Download this Example Code
This video is the test effect:Test Video
Node to node communication
On the premise of no hardware problem, LoRa nodes can communicate with each other node-to-node. The key to success node-to-node communication need make sure the following 7 points the same:
  1. The same sending and listening frequency: LoRa.setFrequency(frequency);
  2. The same bandwidth: LoRa.setSignalBandwidth(signalBandwidth);
  3. The same coding rate: LoRa.setCodingRate4(codingRateDenominator);
  4. The same preamble length: LoRa.setPreambleLength(preambleLength);
  5. The same sync word: LoRa.setSyncWord(syncWord);
  6. The status of LORA_IQ_INVERSION is the same;
  7. the same SPREADING FACTOR;
Know more information about LoRa node-to-node communication, please refer to LoRa basic library APIs: https://github.com/HelTecAutomation/Heltec_ESP32/blob/master/src/lora/API.md
Vext control
The Vext is a power source for external devices. Refer from the schematic diagram.
