How to programming a ESP32 Module
This document uses Wireless_ Shell as an example.
Wireless_ Shell only have ESP32 and RF relevant circute inside. In order to program it, need connect to a external UART-USB bridge. CH340G, CP2102 etc.
1. Recommend Circuit
Please refer to the recommended circuit design for your circuit.
This circuit have an auto boot circuit, can running into bootloader mode automatically.
2. Preparation
Install the ESP32 development framework correctly (Reference resources);
Connect your redesigned board to a computer, make sure useing a high quality Micro USB cable;
Use the serial port debugging assistant to open the serial port and check whether the serial port can print information normally.
3. Program via Arduino IDE
Open Arduino, select “Tools” ->”Board” ->”Wireless Stick Lite”, click “Upload” to start uploading the program. Since the core circuits of Wireless_ Shell and Wireless_Stick_Lite are the same, they can use the same development environment.
