Heltec Wireless Tracker Frequently Asked Questions
How to access boot mode manually(Unable to upload code)
The Wireless Tracker use the internal USB on ESP32S3 instead of a USB-UART bridge, in low-power mode or when a special pin is occupied, the device may not be able to enter the boot loader program, causing you to be unable to download firmware properly.
Entering the boot loader mode needs to meet the following timing (TRST≥10 ms):
Here are two methods access boot mode manually:
Wireless Tracker not connect to a computer – Press the
USERbutton before plugging it to any USB port of a computer.Wireless Tracker already connected to a computer – Keep the
USERbutton pressed → Press theRESETbutton → Release theRESETbutton → release theUSERbutton.
Meshtastic firmware on V1.1 hardware
In hardware version V1.1, the control pin of the GNSS chip power supply was changed to GPIO3, so the official firmware of Meshtatic cannot make it work properly now. Users can temporarily use this version until Meshtastic official accept our PR.
Download the Temporary Pack for Wireless Tracker, flashing with the CLI by following this document.
Connect Wireless Tracker to computer, cd into the unzipped temporary firmware package and install firmware via this command: device-install.bat -f firmware.factory.bin
If you already have firmware in your current Wireless Tracker, it may prevent you from downloading the new firmware. Please refer to this section to manually enter Boot mode and try again.
This issue had been well solved in the Meshtastic firmware 2.2.17.dbac2b1 Beta update. The firmware will automatically recognize the device version and operation it.
Screen not working
When you run LoRa/LoRaWAN related sample code, or factory test code, the screen does not display.
Open the serial port to which the board is connected and press the RST key to see if the board is not activated.
If not, check the link to try activating: How to Use License — main latest documentation (heltec.org)
If the screen does not appear when you run Meshatastick, check that you have downloaded the correct version of the firmware.
