Meshtastic Low Power Settings
Purpose
By adjusting the position and power settings of the meshtastic, the wireless tracker can enter low-power mode to extend the power usage time.
If you are not familiar with Meshtastic, you can refer to this link: Introduction to Meshtastic.
Configuration
Device Config
Role- TRACKER
Position Configuration
Position broadcast interval- 900Smart broadcast min distance- 10smart broadcast min interval- 900GPS update interval- 30Redefine GPS_RX_PIN- 33Redefine GPS_TX_PIN-34Redefine PIN_GPS_EN- 3
Power Configuration
Wait for Bluetooth- 0Super deep sleep duration- 1800Light sleep duration- 900Minimum wake time- 30
Result
After successfully entering low power consumption, the current is only 13uA.
The device is connected to a fully charged 1000mA 3.7V lithium battery and operates normally according to the above settings. After the tracker recognizes the GPS, it can only consume 1% of the power per hour.
Reference linking
https://meshtastic.discourse.group/t/heltec-tracker-v1-and-v1-1-power-config/12016
